I just switched from an Intel 2.8c to the LanParty w/ 3200+. When I first installed the board, it would boot and then freeze after about 45 seconds. After many different options, I found out that when I plugged the CPU fan (Zalman CNPS7000B-CU) into the 2nd fan jumper, rather than the CPU fan jumper, the problem went away, and I was able to do a clean install of Windows XP.
So far so good. I had no trouble installing anything, and the computer was working great. Then I shut it down for a while.
When I rebooted, the computer gave me one long beep, and then went into Windows; however, my screen remained black. After being puzzled by this, I discovered that the video card (ATI 9800 AIW) needed to be re-seated. after that it worked great again. I shut down the computer again for the night, and when I turned it on in the morning, guess what happened: One long beep, bootup, monitor remains black.
After re-seating the video card again, the machine works fine.
Is there any reason why I would have to re-seat the video card EVERY time I shut down the computer?
My specs:
DFI LanParty 250GB
AMD64 3200+
ATI 9800 AIW
Audigy2 ZS
Two hard drives (NO RAID)
DVD Drive
DVD Writer
My specs:
DFI LanParty 250GB
AMD64 3200+
ATI 9800 AIW
Audigy2 ZS
DVD Drive
DVD Writer
