I've got the white Monoprice component cables for my Wii. They seem to work great on one of my HDTVs, however I moved the Wii to the bedroom and some odd problems appeared.
When I first turn on the Wii sometimes you can still see the warning press A to continue screen's text before the Wii menu loads up. It seems to fade away, but remains on the screen briefly before the Menu appears (normally its just a brief black screen). When I turn the Wii off a green horizontal bar flashes across the top of the screen before the TVs display bar appears saying no signal (it only lasts a split sec before the normal display bar appears).
It only seems to do it on the smaller bedroom HDTV, and once the Wii gets to the Menu there are no more video problems and everything looks fine (just video errors on start up and shut down on the console).
Could it be the Monoprice cables even if they work on my other HDTV? I hooked a few other devices up to the component ports (DVD, etc...) on the bedroom HDTV and didn't notice anything like the Wii is doing on start up or shut down.
I tried the Wii on the bedroom HDTV with the standard composite cables and it was fine. I've thought about picking up the Nintendo brand component cables, but I don't want to if it want make any difference over the Monoprice ones. Its obviously a problem with the way the Wii sends a signal over component to this TV.
It doesn't disrupt gaming, but its annoying to see on start up and shut down of the Wii. Will this harm the HDTV in the bedroom? Any ideals of things to try? Should I buy the Nintendo brand cables?
