Odd behavior for vnf3-250 need help - maybe sata related
jazzisjazz
272
Ok I began by setting up this system on my bench before I would put it in a case. I had not yet installed the sound
output card onto the mobo.
I was able to get to 2400 @ 400ddr 222-5, 1.9 chipset, 2.9 v memory. The chipset has a small cooling fan. The processor is colled by a Hyper 6. All seemed well. I saw that the processor would do 2400 for several hours with the latest memtest. I decided to load windows on a 200gb maxter sata drive and run super pi to see if it was truly stable and call it quits at 2400. I tried loading win xp in the middle of doing other things. I let the xp cd format the drive and then started loading the files for setup. At some point the puter restarted and when I came back to it there was a message on the screen saying that NTLDR was missing. I took this to mean that I didn't load the raid driver and the puter could not see the drive - mistake. I also decided to load the os at 1600 default.I installed the sound output card and I turned on the raid settings in the bios and loaded xp again with a quick format. XP loaded fine and I loaded drivers and super pi and clockgen to play around with.
I did some looking around on the net and found that the raid settings and driver were un necessary and so I disabled Raid.
Now comes the problem. The bios seems to be responding slower that it should.
I have reset it several times as I have tried to trace my way back to the settings I used to reach the 2400 oc.
At this point if I reset it it responds "normally" but at oc settings around 250 memory, Htt multi =3, memory freq = 100 so that proc speed = 2000 I must wait 20-40 seconds after striking del toi get into the bios or 20-60 seconds to see the boot options menu. I am wondering if I need to flash the bios or have done some sort of harm to the motherboard to have it behave this way.
I am beginning to think it may be related to using a sata HD, without the hard drive connected I can boot @ 2400 and run memtest.
Is there anything I should be aware of reguarding sata and nf3-250 chipset?
Any help is appreciated
jazzisjazz
htmlmasterdave
1,309
Hey, if you are still having problems with that... it's probably the settings having to do with IRQs... use Auto(ESCD) and disable the reset
