OCZ Modstream Pro 500W
blackrain
1,226
I have the following setup:
AMD X3 720 BE
Biostar 790GX 128M
Silverstone LC13B-E
Sapphire 4850
2 HDs
1 CD burner
A lot of the newegg reviews are saying that the cables are too short on this psu, but its hard to tell which cables. Someone complained about the video power cable, but I think I will be okay. If you look at where the master PCIE slot is on the Biostar board, it is pretty close to the psu. My hard drives are right in front of the psu on the same side of the case so I don't think those will be a problem either. However, the 4-pin power connector, the 24-pin power connector and the cd burner in the 5.25 drive bay are on the complete other side of the case, so this worries me. Also, they may have to go over or around the Sapphire 4850
Can someone have a look at my board layout and let me know if they think I will have any problems.
