6800 GT @ 410/1100. This happens when i use Coolbits as well and doesn't seem to matter what driver its running on. Basically when I set the 3D OC in Rivatuner the 2D memory clock gets overclocked as well for some reason. Or in reverse if I try and return the 2D memory back to default the 3D memory clock goes back to default as well. Its like the 2D and 3D memory clock is stuck together. The core clock is fine either way however.
Id rather not have the trouble of having to setting the memory clock every time I want to play a game, but at the same time its probably not good to have the memory OC'd 24/7. Is this a normal problem and is there a way to get around it?
