Computer Case: COOLER MASTER Elite 430 (With 120mm front intake fan, 80mm bottom intake fan, and 80mm rear exhaust fan)
Motherboard: MSI 970A-G46 AM3+ (According to speccy, my motherboard temps seem to usually be at 35c)
Processor: AMD Phenom II x4 965 3.4ghz (OCed to 3.8ghz @ 1.5vcore with stock cpu cooler, any lower on the vcore gives me blue screen :/. Temps are 43c idling and 60c under full load running prime95)
Video Card(s): HIS Radeon HD 6670 1GB GDDR5, HIS Radeon HD 6670 1GB DDR3
Hardrive: HITACHI Deskstar 7K1000.C 0F10383 1TB 7200 RPM
Ram: Not sure what this is, since this was just Ram i salvaged from a HP Pavilion P6000 series computer. But according to Speccy it says this for my ram, 4.00 GB Single-Channel DDR3 @ 760MHz (9-11-11-29).
Okay well, right now ive got my Phenom OCed to 3.8ghz at 1.5vcore and i was wondering if i can reach 4.0ghz at the least with my motherboard because ive heard a lot of bad things about the vrms failing under a lot of load and heat or something like that. So considering the vrm issue ive heard about this board would i benefit from buying a COOLER MASTER GeminII S524 since the fan would be blowing air at the motherboard to help cool things? Or would i do fine with a COOLER MASTER Hyper 212+?
Also, would buying faster Ram help me reach 4.0ghz easier? Or would i do just fine with value ram? If so, should i buy new ram first or a new cpu cooler?
