Here's what I'm running:
P4 3.0C @ 3.4, 227mhz FSB (or ~900mhz, however you look at it)
Asus P4C800-E Deluxe
1gb Kingston HyperX pc4000
Antec 400w psu
Now, when I look in the BIOS, it shows my memory listed as DDR400. Is this common?
Today, on a whim, I ran CPU-Z (v. 1.23.1), and on the memory tab it shows (besides the memory being pc3200):
Frequency = 151.4 mhz
FSB
RAM = 3:2
CAS # latency - 3.0 clocks
RAS # to CAS # delay = 4 clocks
RAS # Precharge = 4 clocks
Cycle Time (Tras) = 8 clocks
Now, I don't understand alot about overclocking memory, but if I'm reading this correctly, I'm running a divider, and my RAM is running way slower than it should. Shouldn't pc4000 be able to run at a < 230mhz FSB at a 1:1 ratio with no problems? Am I being cheated out of some noticeable "real world" performance gains with my RAM running so slowly? TIA for any input you guys can give me.
Antec 400w psu
FSB
