OCing my new system is not going well...
machu
48
Here is my setup:
ABIT NF7-S rev 2.0
GAIL PC3500 2x256
BARTON 2500+
Swiftech 462
OC Level II 9700Pro
Seagate Cuda V SATA
XP SP1
Without overclocking I tried 3D Mark 2001se and I got 15120. Then I decided that I need some OC action. I lowered multiplyer to 8 and started to raise FSB. XP would not boot with anything over 180. I tried to raise RAM voltage but it wouldn't help. Chipset is at 1.7 which is the max value. THen I got pissed and set the FSB to 200 - Window system files got corrupted. Now I'm reinstalling XP :(
boyRacer
18,569
that's one hell of a system you got there... but i'm not sure if the bartons are overclockable like the T-breds... :(
machu
48
Five hours later, 3 new installations of XP, 5 recoveries through recovery console I finally got something going. I relaxed RAM timings to 7-3-3 cas 2 and so far everything is running smoothly. I'm at 2210MHz (170x13). I think now with relaxed RAM timings I could try bumping it higher, but I'm so scared XP will get corrupted and I'll have to install OS again that I think I'll leave it like that for a while.
I've got 17,041 on 3DMark2001se - compared to my "old" GF3 at ~7000 it is a speed demon.
Shimmishim
7,504
only 170??? that's weird....
i would expect at least 200
have you tried the penicl trick yet on yoru board?
cowdog
283
Check out this article. There is speculation that current nForce2 boards have problems running higher FSBs with a 333mhz fsb cpu (Bartons). Cutting the L12 bridge apparently fixes this issue (details in article), and people are able to get higher FSB from Barton cpus = better OCing.
I am about to build a new work computer, and I have ordered Abit NF7-S and Barton 2500+. I hope to OC a bit, and I found this information in my search. I am now tempted to simply plug in an inexpensive 2100+ and run that until 400mhz fsb chips become available. On the other hand, cutting the L12 bridge doesn't seem too involved, and I am tempted to stick it out with the 2500+. I'll have to check and see if my order was placed yet (University bureaucracy sometimes has benefits).
Anyway good luck.
machu
48
Today I cut the L12 Bridge (Actually I zapped it first with 9v and then cut it - just to make sure I don't have to do it a second time)
Yesterday booting to XP with RAM over 170 was impossible. Today I'm running stable at 220x10
3DMark: 17828
