I would like to OC one of the new P4C (either 2.4 or 2.6) procs to 3ghz safely with just stock air-cooling. Would this be possible and still maintain a very reliable system? If so, which proc would you recommend; 2.4 or 2.6?
Also, based of reading reviews, I am probably going to go with either a IC7 or IC7-G mobo. Would I need to run high-end ram like Corsairs DDR400 to be able to OC safely and successfully? Or would I be OK with ram that is a step or so lower like Kingston XMS or Crucial?
Any advice would be greatly appreciated! 3ghz is my goal while still maintaining maximum stability.
TIA!
TIA!
