Heyas.
See, I have this cas2.5 256MB 333MHz DDR memory, and I'm wondering about things.
First: I though original memory was defined by the actual memory-circuits being made by the same guys as the memory-board?
Second: How big of a chance will I have of running my cl2.5 memory in cl2 ? It's apacer memory with infineon circuits, if that matters much.
Third: As for cas2; how much can you normally overclock the fbs if you have a normal cl2 memory set to 'medium' cl2-timings before the memory complains and wants to have higher timings? Is there a big difference between cl2 and 2.5 memory here?
Thankyoiouverymuch.
Thankyoiouverymuch.
