- Apr 25, 2004
- 109
- 0
- 0
Finally got my new system up and running. Unfortunately, I have not been able to OC my Athlon XP mobile 2400+ very high - i've reached my limit at 2.3GHz. At this speed, I have to use a whopping 1.8v for the core to get it stable, which runs at 55C under full load. For comparison, i can run it at 2.2GHz only using 1.675v stable, 49C full load. I can also pump the FSB up to 210 stable @ 2.3GHz. Since i'm running dual channel, it seems to help the performance a bit with the faster FSB. I can get timings of 2.5-3-3-7. Does anyone have any advice what I should run the processor at? Is 55C too hot?
One of my larger concerns is that when i'm running the chip at anything above ~1.8GHz, *something* in my case makes a very high pitched sound, which is pretty loud and gets on my nerves fast. I can't tell if its my power supply or processor, but it seems to be coming from the CPU area, which means it might either be the CPU or the capacitors next to the CPU. When I start using the CPU (game, prime95, sandra), the sound goes away, or makes a very quiet "chirping" sound. I don't know why this is happening, but it has be slightly worried (and annoyed). Has anyone else experienced this?
