Occassional System Crashes, assorted other nonsense.
Augmenter
Well, I had a bunch of random system crashes happen during printing and installations (strangely enough, not during gaming). Replaced video card, but I had another a few minutes ago while opening a word document. I thought it was my old video card, which managed to get snow and video corruption, and is now on RMA.
However, I am still having problems.
Now, I need some help trying to find out what it is:
Specs:
AMD ATHLON64 3500+ @ stock
ASROCK ULi1695 Chipset Motherboard (those ones with both AGP and PCI Express)
4x 512 DDR SDRAM PC3200 @ stock, reduced motherboard chosen speeds
ASPIRE 500 WATT PSU
40 + 80 GB WD HDs
Audigy 2 Value
Radeon 9800 Pro AGP in slot (used to be 7600GT in PCI-Express slot)
Windows 2000 SP4
Cool N Quiet Enabled
I thought it might be the PSU, but voltages look alright; and so do temps:
Field Value
Sensor Properties
Sensor Type Winbond W83627HF (ISA 290h)
Temperatures
Motherboard 30 °C (86 °F)
CPU 33 °C (91 °F)
WDC WD800JB-00ETA0 31 °C (88 °F)
Cooling Fans
CPU 3245 RPM
Voltage Values
CPU Core 1.31 V
Aux 2.43 V
+3.3 V 3.31 V
+5 V 5.00 V
+12 V 12.40 V
-12 V 4.51 V
+5 V Standby 4.97 V
VBAT Battery 0.06 V
Debug Info F FF 34 FF
Debug Info T 30 33 253
Debug Info V 52 98 CF BA CC EC FF (01)
Any suggestions?
pkme2
3,896
Quoted from another source "Aspire > Dangerous! They don't even pretend to meet the ATX/AMD/Intel specs!'
Change PSU's before something serious happens to your rig.
bruceb
8,874
111
Agree ... that sounds like the power supply is starting to go.
Swap it .. if still same trouble, next step would be to run Memtest86
http://memtest86.com/
on the RAM and if that is ok, run a Hard Drive Diagnostic
Also clear out all the Dust and check the Motherboard for Bad Capacitors
http://badcaps.net/
