Ocassional graphics problem
AyashiKaibutsu
9,306
Everyone once in a while when I start up my computer, I get vertical and horizontal lines all over my screen. Restarting fixes this, but I'm concerned why this is happening.
nater
3,135
Sounds like your monitor might be going bad. Try connecting a different one to see if that resolves the issue. If not, it is most likely a video card problem. If that is the case, I would try reseating your video card and seeing if that fixes the problem.
Delorian
590
As well as naters good suggestions I would also check the cable going from your monitor to your video card. If one or more of the pins in this cable are bent, I would (with a small screwdriver or other tool) VERY CAREFULLY bend the pin(s) back into a straight direction, it doesn't take much force to pop one of these off. Much more unlikely is a heat issue or driver issue, all else fails check that your video card's fan is working properly and is not clogged with dust and also try reinstalling/updating your video drivers.
