There's a article here where a E2160 (with P35) is OCed to 3.33G but idles at 2.22G with a 6x multi. Seems to be a pretty good OC with EIST enabled, doesn't it ?
No, the processor determines how high you can overclock with EIST enabled. So, if they got to 3.3 Ghz with it still on, they'd have gotten higher with it disabled.
