I am trying to squeeze a bit more power out of the below system in order to stave off a CPU/mobo/RAM upgrade for another year or so.
System: C2D e7500 @ 3.93 / GA-P35-DS4 (v.2.0) / 6GB PC 800 Patriot @ 895 / Asus 7870 (stock) / Corsair HX620 psu / Thermaltake Water 2.0 Performer (cooler)
BIOS Settings:
Temps seem okay; under stress test they run mid to high 60s on CPU and System temp. Not sure how hot my ram in running but I have been running 2.2v for a while now. The other settings and the cooler are new.
I have a few questions for the community about this setup:
1) How are my voltage settings? Safe, too high, can they be pushed a bit more?
2) I cannot seem to trim the timings on the RAM (Id like to see 4,4,4,12), but should I bother? If there is noticeable performance to be gained, where would I start to try to get a bit more out?
3) The is a board specific question: the ability to go higher on the CPU overclock seems to be limited by my RAM, as it is forced to higher speed by the System Memory Multiplier in the Gigabyte bios. Am I missing something, is there a way to set to a 1:1 multiplier?
Thanks
BIOS Settings:
3.93 gHZ (358X11)
RAM @ 895; 5,5,5,15 (Motherboard doesn't allow 1:1 as far as I can tell so the System Memory Multiplier is set at 2.50)
DDR2 Overvolt: +0.40 (2.2v)
FSB: +0.15v
gMCH: +0.125v
Loadline Enabled
CPU vCore: 1.36875v
LinX: 20 passes successfully (set to Max 75C not hit)
Prime95: 4(ish) hours w/o errors
Thanks
