OC voltage and stability
moonbogg
10,731
3,440
Something cought my attention. My CPU @ 4.5 with 1.35v offset was mostly stable, but BF3 crashed once. So I upped the voltage one notch to 1.36v, and now nothing crashes and its Intel burn test stable for at least 10 runs as well? one little voltage bump like that can make a difference from unstable to basically totally stable? I haven't done a 12 day run of Prime or anything, but its pretty stable with such a small bump in voltage. I would think it would take a bit more voltage to get stable. What say you? NORMAL?
Kenmitch
8,505
2,250
When using offset vcore it's the single/dual core load that can sometimes cause instability. Upping the vcore slightly can remedy this issue. Kinda normal I guess you just need to find the fully stable vcore.
Using something like Intel Burn Test and testing with only 1 thread and 2 threads will help for long term stability testing.
Ken g6
Moderator
Dec 11, 1999
16,711
4,671
75
Imagine a computation circuit on your CPU like a roller coaster. Under normal conditions it works fine, but if you don't give it enough energy (kinetic/voltage) to get over every single hill, it will get stuck someplace.
moonbogg
10,731
3,440
I like that analogy. Thanks guys for replies. Appreciated indeed.
