- Sep 6, 2000
- 245
- 0
- 0
I have dual celery 366's currently running at 458's and i would like to get these to 550.
I am running a BP6, two celeron (OEM, MALAY chips) 366's, V3 3000, aureal vortex2, intel etherexpress pro 10/100, and a 2940UW...
here is the problem...
I did run 224MB of SDRAM (one stick of normal SD 32MB, one stick of Atlas precision 64MB, and one stick of PC100 128MB).
when i tried overclocking with this setup, i could not get past the 86*5.5=458 point (even with the 66MHz ram in there). so, when that didnt work, i decided that i would just remove the excess 96MB and go with the PC100 stick to OC. I did this and found that i STILL couldnt go past that point (couldnt get to 100*5.5 without it locking up within the first few minutes of booting, or while booting itself).
i would think that running at 83MHz bus would be more difficult then the 100 since 83 is overclocking EVERYTHING and the 100 would clock the AGP and PCI busses back to normal.
with it at 83MHz, it never gets above about 40C.
I am using OEM (stock) HS/fan for the cpus and have plenty of case cooling.
ANY helpfull information on HOW i can get this thing up to dual 550's would be great
PS, i am running win2k PRO, have a phatty scsi drive, and two cdroms (one is a burner).. all scsi
