Oc Problems (Plz Help!)
Panthr710
47
I am having problems OCing, I just bought a new rig (see specs in my rigs section)
I can get it to run anywhere close to 1533 where it is supposed to clock. ( I think i have it now at 11.5 clock multiplier and 120 fsb)
Any suggestions, i dont know what else to say.
Ask and ye shall know :)
Dan
Boonesmi
14,448
why do you have it at 120mhz fsb???
at 120mhz your pci and agp will both be way out of spec, that means any onboard device or addin card could be a limiting factor
the more i look at it the more i suspect 120mhz fsb is a typo
edit to fix some spelling :)
MeTaLrOcKeR
22
<< I am having problems OCing, I just bought a new rig (see specs in my rigs section)
Dan
11.5 Multiplier X a FSB of 120 is only 1380MHz...
a AMD Athlon XP 1800+ (1533MHz) uses a FSB of 133........so please clarify what your talkign about in your post......
Boonesmi
14,448
edited because im tired and my eyes just played a trick on me :) hehehe
pci and agp bus run as a fraction of the fsb (everything from onboard sound to hard drives are included on the pci bus)
at 100mhz fsb the pci is set at 1/3rd and the agp is set at 2/3rd... this means when the fsb is 100mhz the pci is running at 33mhz and the agp at 66mhz
when you go to a 133mhz fsb the ratio changes to 1/4th pci and 1/2 agp meaning the pci is once again at 33mhz and the agp is at 66mhz
but... when you run the fsb at 120mhz your still at 1/3rd and 2/3rds, this means your pci bus is running at 40mhz and your agp is running at 80mhz
many pci devices will not function at 40mhz... this could cause the system to not post at 120mhz fsb :)
Panthr710
47
Here are your answers :)
yes it is @ 120fsb, I have tried, multiple times to run it at 133 and it wont work
it is clocked, but i am changing it through the ASUS bios on the A7V, so im not sure what that means :)
Thanks again
Dan
Boonesmi
14,448
*** edit *** uhhh i deleted my post :)
you dont have an a7v silly, you have an a7v266 :)
Panthr710
47
The power was my initial thought, I have a 350 PSU (dont know the maker) but i am going to get a new Antec 400W for christmas, so once i see if that works, ill get back to you guys.
Panthr710
47
Sorry for the delay, but i was on vacation.
An update, I got the SX840 for my case, when i finished hooking it up, it immediately started up on the O/Ced FSB frequency. Thanks a ton for all your help!
I have one more question, what other FSB frequencies will work, I know the *33's will work, but what else. Or should i try to mess with the clock multiplier instead? Thanks a bunch
Dan
