OC Help: I am having issues trying to get Ryzen system stable.
unseenmorbidity
1,395
967
System specs:
Ryzen 7 1700
EVGA GTX 1080 FTW2
Asrock Taichi
Noctua D15
Gskill TridentZ 4000
Samsung 850 EVO 250gb
I have had the system stable at 3.9GHZ & 3200 CL14, but the OC I am aiming for is 3466 CL14 & CPU 3.9 GHz.
Current Settings:
CPU:
3.9GHz
1.3685v (I have tried up to 1.4v to no avail)
Memory:
1.4v (I have increased this up to 1.45v, and it didn't help)
SoC: 1.15v (I have increased and decreased this, but it always become less stable)
53.5 Ohm
The system will pass several passes of memtest, but Aida64 will crash within 4 hours.
I tried increasing the tRC & tRAS, but that didn't work.
I tried increasing tRFC to 300, but that made it worse as well.
Anyways, any tips?
Zor Prime
1,044
622
For sake of curiosity ... does it crash under regular use, or just when stress testing?
VirtualLarry
56,587
10,225
Just a note, I have read that with the current Ryzen 3,5,7 CPUs, the relationship between the memory controller and the CPU overclocking, since the CPU has internal capacitors, it can only supply so much max power, so that overclocking the CPU cores to "max", as well as overclocking the RAM to "max", may not be as easily possible, as overclocking each one individually.
This is probably not altogether that different than overclocking higher-end Haswell CPUs, because of their FIVR.
(*) And those parts inside of Ryzen, they might be inductors, and not capacitors, I don't remember exactly.
DrMrLordX
23,160
13,254
If you look at Silicon Lottery, only a smallish percentage of 1700s will even hit 4 GHz. So you may have lost the "silicon lottery" there.
Same basic deal with the IMC.
I got soooooo close to DDR4-3600 but I can not make it stable, no matter what I do, on my 1800x. Just off the cuff, I'd say you've done your homework and found your limits. Though I can show you the timings for my b-die and let you try them. I use 1.42v vDIMM and 1.175 SoC voltage fwiw. It's DDR4-3466 14-14-14-28 stable @ 4.0 GHz (when I want it).
Markfw
May 16, 2002
27,378
16,220
Take everything back to stock, then up the speed, and the CPU vcore only SLOWLY.. I think you can get 3.7 or maybe 3.8, beyond that, its the lottery,.
Reactions: VirtualLarry
unseenmorbidity
1,395
967
I have removed the CPU OC altogether, and I am still having trouble getting 3466 to pass aida64. It seems more stable, but not completely there. I think if I had to drop the OC from 3.9Ghz 3333 vs 3.7 GHz & 3466, then I would be better off with the 3.9GHz, wouldn't I?
Markfw
May 16, 2002
27,378
16,220
I have removed the CPU OC altogether, and I am still having trouble getting 3466 to pass aida64. It seems more stable, but not completely there. I think if I had to drop the OC from 3.7 GHz & 3466 vs 3.9Ghz 3333, then I would be better off with the 3.9GHz, wouldn't I?
Personally I would go with the higher memory speed. Also check your timings. If you can tighten those up, it will also help.
IRobot23
601
183
System specs:
Ryzen 7 1700
EVGA GTX 1080 FTW2
Asrock Taichi
Noctua D15
Current Settings:
CPU:
3.9GHz
Memory:
53.5 Ohm
Anyways, any tips?
Did you try with base clock?
Like 103MHz?
unseenmorbidity
1,395
967
OP, try these RAM timings with vDIMM 1.42v and SoC 1.175:
https://www.dropbox.com/home/bench?preview=1800x4075CPU3466RAMCineBenchR15.png
Some of your timings may be a bit off. These work for my DDR4-3733 sticks on an 1800x, and I have the same mobo as you as well. Give em a shot. If those don't work try some of the timing sets that chew* has over on XS.
That link takes me to my dropbox home page. I have never used Dropbox, so I might be doing something wrong, idk.
Like 103MHz?
I have not. What is the number that changes the PCIE to 2.0? 105?
I will look into that, ty.
IRobot23
601
183
C6H will maintain PCIE 3.0 up to 104.8MHz over that PCIE 2.0.
Try this one
Base clock : 104MHz
Memory multiplier : x16.67 (3333MHz)
SOC V : 1.125-1.15V (first 1.125V)
DRAM V : 1.425V
104 * 16.67 = 100 * 17.33
Also someone posted DDR4 calculator make sure your timings and V are good to go.
