Originally posted by: stevejst
1.55v but it fluctuates from 1.47v - 1.53v.
I have IS7-E and IC7 and they are both undervolting. IS7-E was bought new. Similar to yours. Just set it on 1.55 or 1.575 and you'll be OK. This could be also a consequence of a power supply but I do have Enermax 350W and Antec 550W that I used before with no problem. So it might be just the way Abit boards are. I get 3.00GHz with no problem at all, actually fairly easy to 3.2 GHz on both boards. You should be doing that as well. Use 5:4 ratio for bus:memory.
Find the way to cool the ram (fan close by), I get about 2 MHz more on FSB doing this, hard to believe.
Another thing - what kind of fan you have on the chipset?
Fan on the chipset? It's the stock cooling fan on the motherboard. Oh, btw, im at 233fsb / 466ddr, 1:1 ratio, 1.575v, actual ranges from 1.50v-1.55v. I'm pretty sure my case setup is a big reason i cant go 3.2ghz stable at a decent voltage. Its a really old case, thats got no fans in it except for the psu fans, cpu fan and mobo fan. Heres some pics.....
LINK lol. My case is 6 years old.... didnt have money at the time to upgrade my case, but i plan to get a new case within the next couple months. Maybe when i get it ill try pushnig my cpu some more, but this is the farthest i want to go right now, i dont want to push my voltage any higher. And yeah, WTF is with all the AMD THREADS!
EDIT*- Forgot to mention, the pics you see of my case in the link is exactly how it looks right now. Theres no cover for the case, nothing is screwed in, not even the hard drives. And the floppy drive is still on its side sitting inside the case. Hehe, i need a new case bad!
