OC ECS P4M800Pro-M with PD 930
irenealan
382
Hi everyone, I saw this ECS P4M800Pro-M and Pentium D 930 combo for $160 and wonder if this ECS would work well OCing the Pentium D 930? Anyone has experience with it?
Another reason I want to get to combo is I have a spare AGP 6200 vid that I would like to put together with this system... if I have an Antec TruePower 330w, do you think if it's good enough to run Pentium D 930, AGP 6200, DVD Writer, and 2 IDE HD? Thanks very much for your help!
o1die
4,785
Overclocking? Not with the ecs boards. Very few ecs boards have voltage adjustments. If you want to overclock, the 805 combo would work better, but Fry's was only offering it with a ddr2 motherboard awhile back. For the power supply, I would just try it first. It's marginal, but may work fine without overclocking. Have you considered the heat issue when overclocking? There's another post in the cpu section about the temps with 930.
