So, I got my new system finally set up and gamed on for a few days, figured it was broken in enough to start my OC. This is the first I have done in some time and the last was an AMD so I need a few clarifications.
Here is the Setup:
Intel e4500
Gigabyte P35-DS4
EVGA 8800GT Superclocked
Crucial Lanfest 800mhz 4-4-4-12 (basically Tracers)
Tuniq Tower 120
Ultra 700w PSU
Ultra Grid Case
Soundblaster X-Fi
WD 1600AAJS
I started out aggressive, hoping I'd get lucky with a super CPU right off the bat hehe. 8x400 1:1 at stock voltages but no such luck
So, I went with something a little more conservative and decided to thoroughly stress it first as I was having post issues with high FSBs and it was getting late.
PIC of CPU-Z, Orthos, Everest, Core Temp
Went with a nice 266x11 for just under 3ghz and that 1066 FSB. Now what I'm wondering is, in the bios when I put the mem divider at 2:3 it said the speed would be 800. CPUZ reports 399 @ 2:3 and Everest reports 388 @ 12:8 (which I guess is 3:2 and the same thing?)
Now according to the How to OC Core 2s article:
So does that mean I'm running my memory at 1200mhz? I'm a little confused here. Damn Intel and your FSBs
So anyway, after 17 hours of Orthos my temps were stable at around 48C at 1.338 vcore and 2.0 vdimm, is that good for this amount of OC and a Tuniq? I read in the temp article I should be safe at almost 70? I did not lap my cpu or heatsink.
I was kind of hoping to get the RAM to be running at the same MHZ as the quad pumped fsb, ie both at 1066, is there any advantage to that or would I be better off with tighter timings at around 800mhz with the RAM?
Comments welcome, I'll post some SuperPI and 3D mark later tonight.
Here is the Setup:
Intel e4500
Gigabyte P35-DS4
Tuniq Tower 120
Ultra 700w PSU
Ultra Grid Case
Soundblaster X-Fi
WD 1600AAJS
Most good boards will offer 5 modes listed below. Assuming that you?re using a 333 MHz FSB the ratios are:
FSB : DRAM
1:1 = 333 MHz : 667 MHz
4:5 = 333 MHz : 883 MHz
2:3 = 333 MHz : 1,000 MHz
3:5 = 333 MHz : 1,111 MHz
1:2 = 333 MHz : 1,333 MHz
