I have tryed to OC my CPU for the last 3 days now and I cant get it to OC at all. I really need help its driven me crazy. I am kinda new to OC so any help would be appreciated. I have done so much research I am about to cry lol so I saw alot of ppl postng at this fourm and everyone seem to try to help ppl so here I am
Specs
Intel E2160
Gigabyte P35-DS3L
K DATA 3G DDR
Nvidia Geforce 8800GT
Here is what I have tryed so far its alot so bare with me and like I said kinda noobish with this OC stuff. I will post some of the stuff I tryed in Bios below
CPU Enhanced Halt (CIE) = Disabled
CPU Thermal Monitor 2 (TM2) = Disabled
Robust Graphic Booster Auto
CPU Clock Ratio 9X Tryed x8 with the mhz att 333 and for some reason it under clock the card to 1.6 when it should have been 2.66
CPU Host Clock Control Enabled
CPU Host Frequencey (mhz) 333 Tryed everything to OC from 2.0 all the way to 3.0 it just wont OC at all
PCI Express Frequency (mhz) auto Tryed 100
C.I.A.2 Disabled
Performance enhance standard Tryed Turbo at x9 and 333 mhz just to see what happen no change
System Memory Multiplier (SPD) [2.40] tryed auto and everything els. i tryed to get it as close to 800 800 when I OC. Also for some reason when I do Try to OC when I restart sometime it will show the Ram at like 480 or 680 and so on even tho I have it set to 800 800 or 800 1330 or whatever it is
Memory Frequency (Mhz) 800 800
DRAM Timing Selectable (SPD) [manual]
CAS Latency Time 5 [5] Tryed 4 when i tryed the 4 4 4 12 it wouldnt boot
DRAM RAS# to CAS# 5 [5] Tryed 4
DRAM RAS# Precharge 5 [5] Tryed 4
Precharge delay(tRAS) 18 [18] Tryed12
ACT to ACT Delay (tRRD) 3 [Auto]
Rank Write to READ Delay 3 [Auto]
Write to Precharge Delay 6 [Auto]
Refresh to ACT Delay 42 [Auto]
Read to Precharge Delay 3 [Auto]
Static tRD 7 [Auto]
Static tRD Phase Adjustment 0 [Auto]
System Voltage Control [Manual]
Ddr2/ddr3 OverVoltage Control [Manual]
PCI-E OverVoltage Control [Normal]
FSB OverVoltage Control [Manual]
(G)MCH OverVoltage Control [Manual]
CPU Voltage Control [1.45000] I also tryed 1.4,1.42,1.50 on everytime I tryed to OC. Even tryed to OC it at 2.4 with 1.45 Voltage and still nothing I cant even OC it to 2.0 from 1.8
Normal CPU Vcore 1.32500V
Like I said if anyone is willing to work with me here id love the help. I dont know what I am doing wrong I read that this cpu and MB works great to OC it to 3.0 but the computer just wont do it. My friend said it was easy all you have to do is set it to x9 at 333 and make the ram 2.40 so it reads 800 800 and give it some more Voltage and it should be easy as that. This post is my last hope before I go insane so please help me. I try about anything to get this to work i have spent over 20 hours trying to get this to OC in the last 3 days even with research.
Specs
Intel E2160
Gigabyte P35-DS3L
K DATA 3G DDR
C.I.A.2 Disabled
Static tRD 7 [Auto]
