nullpointerus
I've been wondering something for a while now. Why don't case manufacturers just make cases that mount the PSUs upside-down with a 120mm hole on top of the case and a dust filter to obscure the real fan size of the PSU? This idea should make for much better cooling as the PSU's airflow would be separated from the rest of the system (instead of competing with it!), and I really don't see how the mounting would affect compatibility significantly enough to lose many sales.
Anyway, I'd like to mod my Antec SLK-3000B to support this. I don't have a dremel, but I did read something about a 4" hole cutter in some topic. What I really need is details. You see, I have a cordless screwdriver with a drill setting, but I'm not familiar with drilling. I do know that the time it takes to cut through case material can increase dramatically if I use the wrong type of blade. I believe it's a steel case. Also, I'll need to drill some extra holes in the back of the case due to the screw layout of ATX PSUs. Do I need special bits for steel? Or would standard bits (i.e. for wood) work fine?
