Obtaining a universal reference frame using time.
Discussion in 'Highly Technical' started by Ben90, Dec 20, 2012.
  1. Ben90
    Ben90 Platinum Member
    Jun 14, 2009
    2,866
    Lets have three observers: ClockA, ClockB, and Earth. Shoot the clocks off in directions in which gravitational forces are the same for both clocks. The clocks then relay their time to Earth, and the one whose time has passed the most is closer to a standstill. Rinse and repeat.
  2. Loading...
    Similar Threads - Obtaining universal reference Forum Date
    Universe Size Comparison in 3D! Highly Technical Mar 27, 2017
    Is the universe/galaxies all on a general plane? Highly Technical Dec 31, 2014
    Universe expansion is accelerating ? Highly Technical Sep 22, 2013
    What happens to light at the end of the universe? Highly Technical Oct 23, 2012
    How to obtain detailed DVD format? Highly Technical Oct 11, 2004
  3. Paul98
    Paul98 Diamond Member
    Jan 31, 2010
    3,560
    15
    There is no universal frame of reference, it's all relative. In clockA's frame of reference it is not moving, in earth's frame of reference clockA will have a speed. The velocity depends on the frame of reference you choose.
  4. MrDudeMan
    MrDudeMan Lifer
    Jan 15, 2001
    14,846
    30
    I don't have a clue what you are trying to propose, but Paul98's reply is right and disproves your theory regardless.
  5. stevech
    stevech Senior member
    Jul 18, 2010
    203
    Universal time reference per today's scientists, is the instant of the Big Bang, is is not?
    (until that theory is superseded).
  6. Paul98
    Jan 31, 2010
    3,560
    15
    No
  7. pw38
    pw38 Senior member
    Apr 21, 2010
    295
    There is no "universal" reference. Hubble proved that.
  8. Paul98
    Jan 31, 2010
    3,560
    15
    Hubble did not
  9. tracerbullet
    tracerbullet Golden Member
    Feb 22, 2001
    1,559
    This.
    Their being shot off mimics gravity and is part of it. What's done with their info that is sent back depends on when they shoot the info back (according to their own clock) and how far it has to go to be received. You're missing a lot of things and don't actually seem to have a question. In fact, is the original post a question, a solution to something, what?
  10. Cancer12
    Cancer12 Senior member
    Nov 30, 2001
    510
    Mine is clearly the correct reference point, end of discussion. It always is consistent for me.
  11. silverpig
    silverpig Lifer
    Jul 29, 2001
    27,710
    There may very well be. It's the frame in which the dipole term of the CMB is zero.
  12. jimhsu
    jimhsu Senior member
    Mar 22, 2009
    703
    The problem with solipsism is not getting other people to do the same.
