So.... we are redoing our kitchen and already put up the backsplash and/but left some exposed unpolished edges of the stone. Reference the pic.
There was no special edge version of this.
Now.... I understand it would be really hard or basically impossible to put a mirror like finish on all these edges, but I would like to try and do something. I took my dremel to some spares stones we had and used the fine-sanding bit, felt tip w/ polishing compound and then the felt wheel. Results are mild at best, but the main problem is that I can't seem to remove the polishing compound afterwards.
Can anyone here recommend a better method or set of tools for doing this? Anyone have any tricks for removing excess polishing compound?
