[Objective] C Preprocessor macro possible
nickbits
4,122
I have a bunch of code that relies on a preprocessor constant.
I'd like to have a macro that conceptually works like this:
#define A_OR_B(a,b) \
#ifdef A \
(a) \
#else \
(b) \
#endif
And I'd use it like abc(A_OR_B(1, 2));
Right now I'm doing:
#ifdef A
abc(1)
#else
abc(2)
#endif
And I don't like that. Any suggestions? I'm using objective C. I thought I might be able to do something with a C++ template but objective C isn't a superset of C++, only C.
I could have a function that that does the check but I'd rather not have the function call overhead... but right now I think that is a better idea than all my #ifdefs...
mosco
940
What's your concern about function call overhead? Is this going to be called a lot?
Can you give some more detail about what functionality you trying to switch between?
Ken g6
Moderator
Dec 11, 1999
16,838
4,817
75
Well, this works in C:
Code:
#ifdef A
#define A_OR_B(a,b) (a)
#else
#define A_OR_B(a,b) (b)
#endif
uclabachelor
448
#ifdef A \
(a) \
#else \
(b) \
#endif
#ifdef A
abc(1)
#else
abc(2)
#endif
I'd go with Keng6 wrote or, something like:
Code:
#ifdef A
#define A_OR_B a
#else
#define A_OR_B b
#endif
Your original code is too hard to read. Keep it clean!
nickbits
4,122
Not really concerned with the overhead as much as I think there should be a better way.
I have 2 targets in my project that have different features enabled and I have some coordinates that depend on the target.
nickbits
4,122
Code:
#ifdef A
#else
#endif
I don't think that works. It would require the pre processor to make 2 passes which I don't think it does. I think that was the first thing I tried but maybe I'm wrong.
Ken g6
Moderator
Dec 11, 1999
16,838
4,817
75
It works. I tested it. :colbert:
Code:
#include <stdio.h>
//#define A
#ifdef A
#else
#endif
int main(void) {
  printf("A OR B is %s\n", A_OR_B("A", "B"));
  return 0;
Uncomment #define A to change the output of A_OR_B.
