If he's gaming he isn't going to need a optical drive?
I guess that I prefer to have a hard copy of whatever software I have.Not most of the time anymore.
Optical media is slowly going the way of the dodo. Most games don't bother with it anymore. Some of the 'new' ones have even gone as far as using the CD to launch a downloader.
I try to find a way around this like just for example; Adobe Reader. You go to their website, download a downloader (which makes no sense to me in the first place), then the downloader downloads Reader. What I do is go to their FTP and just download the full installer. Screw the middle man.
I get it that it can save money for game developers to just make a download by not having to press a CD/DVD. But what if I want to install it on a computer that doesn't have internet access? I know that that is a strech in these times, but I have computers that I don't connect to the internet at all, so it's completely feasible.
I use the Windows 7 USB DVD download tool. It can read the raw ISO and put it on a 4 - 8 gig USB stick for you.
http://www.microsoftstore.com/store/msusa/html/pbPage.Help_Win7_usbdvd_dwnTool
Works for everything Windows 7 and newer so far. Just used it this week to upgrade the office test tablet to 8.1.
I tried this yesterday, just as I have a number of times in the past, and the Window 7 USB tool gave me an error telling me that Windows 8 is not supported. They might have changed it recently.
eh..$12 fer usb vs $20 for dvd burner + less hassles..
Your choice.
+1 I carry one of these in the toolbox and it has saved my ass a few times. I can create bootable USB ISO's with Unetbootin, but flash drives are so slow with writing smaller files that it ends up taking 45-120 minutes whereas a DVD burns in 5 or larger dual layers in 20. What I do with thumbdrives is carry ISO's on them and burn when needed. Saves time because you would have to know well ahead of time what ISO you want on a flash drive.Also, it is a good idea to have an external optical in case you ever need to rip a music CD or movie DVD, or read files archived on a CD/DVD.
I like Rufus for burning isos to USB sticks, and Imgburn to create the isos. There are dozens of ways to do this, but that is what works for me.
http://rufus.akeo.ie
http://www.imgburn.com
If you use ImgBurn to burn a downloaded ISO image of, say, Windows 7 from Digital River, and then you rip the DVD back to an ISO, it does not come out the same as the original ISO, and the MS ISO tool will not recognize the ISO. You have been warned.
Edit: Yes, verify was on while burning, it wasn't due to a bad burn.
I don't think I have run into that. Have you tested the iso>disc>iso>disc with other software successfully?If you use ImgBurn to burn a downloaded ISO image of, say, Windows 7 from Digital River, and then you rip the DVD back to an ISO, it does not come out the same as the original ISO, and the MS ISO tool will not recognize the ISO. You have been warned.
Rafael wrote a tiny downloadable utility program that will fix any .iso file where the last logical block does not have the AVDP so that the Windows 7 USB Download tool will work. Basically, you download the .zipped utility program and extract it. Then copy the .exe file to the same directory as your iso file, then run the utility in command mode pointing to the .iso file. In a second or so, your .iso file will be fixed so that the last logical block is the same size as the rest and the Windows 7 Download Tool will work. I tested it with the Windows 8 Developer Preview .iso I had downloaded and it worked like a charm.
I've never used the Windows 7 USB download tool. I wonder if the problem with the isos specifically affects it, or every other iso to USB burner out there.http://blogs.msdn.com/b/mis_laborat...ws-7-usb-download-tool-with-any-iso-file.aspx
That's the problem. Original ISO from DR has AVDP blocks, but burning it to DVD with ImgBurn and then re-ripping the DVD with same, strips off those block(s), and the MS ISO will no longer work with them.
