Hello.
First, the pertinent system specs:
Abit KG7-RAID
Athlon XP 1600+ (AGOIA stepping)
256 MB Crucial PC2100 DDR (CAS 2.5)
Gainward GeForce4 Ti 4200
Win98 SE
When running at the default speed (1600+) and voltage, the computer is completely stable.
I have been able to push it up to 2000+ (FSB of 159), and it is stable if I bump up the memory voltage to 2.65V.
The problem is this: if I overclock it to 1800+ speeds or faster, even though I can get it to run completely stable in Windows, the computer will not completely restart. For example, if I select "Restart" from the shutdown menu, the computer WILL get out of Windows and begin to restart, but then the monitor light turns from green to amber, and the computer never makes it back. The same thing happens when pressing the reset button on the case -- the restart begins, then the monitor goes off and the computer doesn't make it into POST.
If I then completely power off and turn back on, the computer boots just fine -- no problems at all.
Has anyone seen anything similar before? Any suggestions? Help.
Thanks.
-Arschloch
Abit KG7-RAID
Win98 SE
Thanks.
-Arschloch
