Originally posted by: THUGSROOK
sandra burn in is a joke ~ run something a bit more serious.
as ive said many times before....
the prescott runs so hot and consumes so much power that strange things will happen when it comes to stability.
hints:
USB is 100% cpu dependant. (thats why USB suxors for OCers/gamers)
stability testing w/o using the vid card (gaming) is a waste of time for gamers! (HEAT!)
try playing NFS underground, Serious Sam, or FarCry as a stability test.
how far can you go with the USB garb running?
HTH![]()
Originally posted by: myocardia
Go spend a bit more money, and this time buy a powered usb hub, like the one I bought at Wal-Mart for under $30 (and it's usb 2.0).
Originally posted by: Falloutboy525
also run prime95 on your system without the usb adapter my guess is its still not stable even without it
