o/c problem deleting files
zer0burn
OK got a weird problem here.
specs:
1.8a
it7 max
winxp
ti4600
pc2700 samsung
ok Im at 125 fsb but when I go for 133 fsb winxp deletes one of the system files. I rasied the vcore and everything any ideaS?
Sounds like your pci/agp are being overclocked way to high, but at 133 it should go back to the default 33/66mhz. odd problem there. Is there any settings in the bios to set the agp/pci dividers?
wasnt the memory I kept it at 1:1 ratio so it was running @ pc2100 specs. It was a voltage problem on the CPU
