Nzxt Phantom 410 OR Cooler Master HAF 912 Advanced Mid Tower Cabinet
sandeep3001
Please advice from the following 2 mentioned case models:
1. Nzxt Phantom 410
OR
2. Cooler Master HAF 912 Advanced Mid Tower Cabinet
- do you not have any other options?
- what components are you putting in?
- which one do you think looks better, or does that not really matter?
Out of these two I'd chose the Phantom even if it was more expensive, because the HAF912 reminds me of a tractor.
HAF 912, I used to use it and it was AMAZING. it fit a four way RAID array plus two data drives, maxed out fans, a fan controller, SLI GTX 470's and a big heatsink. Get it, plus the 24-pin cable fits behind the mobo tray.
1. Nzxt Phantom 410
OR
if you are thinking of the HAF 912 Advanced,as i did.Get the HAF X
its the best there is for the sub £400.Unless you are heavily into or getting into games HAF X is the Superior.If your a serious gamer,look up th Antec Lanboy Air.
