NZXT H2 review
airdata
This is an excellent case!!! Bought it for a build I was commissioned to do. Microcenter had it for $95 w\ $20 MIR. The build quality is excellent. It's a solid case, not cheaply made. It's got a ton of features. The one picture below shows a usb 3.0 pass-through cable at the back... the one I got had a different connector to go directly to the motherboard.
There's a built in sata port on top of the case should you need to plug a hard drive into the computer so you don't have to open it up. The fans on the front are modular w\ no wires and simply plug in and pull out easily if you need access to any of the 8 or so hdd bays.
This case is hands down better than the anctec 900 II I use as my main computer.
http://www.youtube.com/watch?v=yVgysQaN4pQ&feature=player_embedded
http://www.newegg.com/Product/Produc...82E16811146071
how are the temps compared to your antec 902? with the sound dampening and what looks like limited airflow, should be a bit higher no?
ah nvm, thought you replaced the 902, didnt see it was a build for somebody else, my bad =)
Except intake airflow sucks balls, without a mod it's just a $110 hot air box =/
Temps were really good. I had an fx 8120 w\ corsair H60 cooler. The H60 came w\ a fan so I swapped it out w\ the one installed in the case and put that fan at the bottom of the case between the psu and front of the case.
Forgot to take pics 🙁 Should have some this weekend though.
