NY Strip steak: Bone-in or boneless?
NY Strip steak: Bone-in (5.99/lb) or boneless ($6.99/lb)?
  • Bone-in
  • Boneless
phucheneh
7,306
The "bone-in" New York Steak is just a T-Bone dude. If they're both the same thickness and grade of beef, might as well go for the cheaper one.
The bone-in is $1 per 2.7oz. The boneless is $1 per 2.3oz. Assuming something average, like a pair of 16oz steaks, the bones would have to weigh less than...wait, I forgot where I was going with this. Fuck math; math is hard. Buy the boneless steaks.
Sep 12, 2004
16,852
59
86
A T-bone has a small portion of tenderloin attached. A bone-in strip has no tenderloin portion. Bone-in strips are not common and are very good.
There are also bone-in filets, which are very rare.
BUTCH1
20,433
1,769
Don't bother with the bone. The bone will have zero impact on the flavor and depending on how you cook it, make it harder to cook properly.
Though I do enjoy gnawing on the t-bone after.
You could not be more wrong, the bone will help the steak retain moisture, add flavor and keep it from curling up on the grill.
BUTCH1
20,433
1,769
Yes, I bet you do. :sneaky:
Weren't you the Programming mod? Isn't that like being Sheriff of Mayberry. :D
Can't imagine too many shenanigans go on in there.
Not really, a T-bone has the full bone structure of the loin with some tenderloin on one side and strip loin on the other, if the tenderloin piece is big enough, (depending on different specs) it can be called a porterhouse. A bone-in strip has been "chimed" on a band saw to remove the part of the bone where the tenderloin was, this is also commonly called a "shell" steak.
Captante
30,316
10,814
Are they dropping like flies?
I am no longer a full mod because I am a moderator emeritus. That latin word at the end means POWER.
Courtesy of merriam-webster.com
emeritus
noun emer·i·tus \i-ˈmer-ə-təs\
plural emer·i·ti\-ə-ˌtī, -ˌtē\
Definition of EMERITUS
: one retired from professional life but permitted to retain as an honorary title the rank of the last office held
So an "honorary" mod? :confused:
Jun 18, 2000
11,151
728
How is a bone attached to one side of the steak going to help it retain moisture? You are exactly the kind of sucker restaurants look for. Hey, feel free to pay more for less meat.
For a typical steak that is cooked medium or medium rare, there will be zero effect from the bone. It will only make it harder to cook the edges evenly. If you are making a stew or otherwise slow-cooking it, keep the bone. Otherwise skip it.
Chocu1a
1,386
79
Strip Steak with bone attached is a Kansas City Strip. Boneless Strip Steak is New York Strip.
Been Cooking professionally for 25 years, in several high end steak shops. No difference in taste or quality.
slag
10,473
Everyone knows there really is no such thing as a NY strip steak. It's a KC strip steak that NY has tried to make its own. Stop trying to make it a thing. Its never going to be a thing..
slag
10,473
Strip steak with bone attached is Tbone or KC strip but bone alone does not make it a kc strip. I can buy KC Strip all day long in KC with or without bone.
Puppies04
5,909
17
Which colour power mod are you?
Are you going to combine all your powers into mega power mod to defeat Alky when he comes back?
deadlyapp
6,621
720
I have cooked a few bone in strips and have a couple more sitting around ready to be cooked. It was a pain in the ass cooking on cast iron and definitely takes a lot longer than boneless. It ended up fine but I definitely had to go back and cook it longer after the first run.
yuchai
980
The bone in makes it difficult to cook the steak evenly. The meat near the bone will take much more heat to cook to the same temp. Not only that, but the meat near the bone doesn't make contact with the cooking surface properly because of the bone getting in the way as well.
The result is that the side without the bone will be done but the meat near the bone is still very rare/raw.
I'm sure that there are techniques that allow you to get around it, but overall probably more trouble than it's worth.
Boneless is the way to go.
DrPizza
Mar 5, 2001
49,601
166
111
www.slatebrookfarm.com
There is only 1 factor which should determine which of the two he purchases.
Does the OP have a dog? If so, get the bone. If not, no bone.
/thread
Chocu1a
1,386
79
Lmao...too true...location, location, location...:D
But serious though, T-bone is off the opposite end of loin cut of Porterhouse. Both contain a strip steak & tenderloin, separated by a t-shaped bone. Porterhouse contains more of the eye of tenderloin, t-bone contains the tail end of tenderloin.
