Nvidia geforce 256 DDR problems
Sep 7, 2000
149
I have the following PC configuraion:
AMD Thunderbird 900MHz
Asus K7M
Asus 6800V GeForce 256 DDR 32MG
128MB PC100 RAM
Maxtor DiamondMax+ 40
Soundblaster 128 PCI
Sylvania F72 17" Monitor
Conexant 56K modem
Win 98 SE
No additional Hardware
My Graphic Card seems to be having some (a lot)compatibilty problems, every game i play has some bug in it like in Unreal Turnament all the shadows and water are displayed wrong and even though i have the newest update for it and the Detanator 3 (which by the way didn't increase my performance even 1 frame). I run Unreal Turnament at 1024x768x32 at about 60 fps in D3D but as I said with errors. When I run the game in the Open GL mode it fixes the shadow problem but the game is increadibly slow 32 fps. The computer is new and i have not installed any damaging software or anything everything should work fine but it doesn't. Can anybody help??? Or is somebody having the same problem?? By the way a list of games with errors UT, NFS4, Homeworld.
Henry Kuo
2,248
did you try using the 5.22 or 5.32 driver instead? you are using athlon system, 6.18 driver might not be the best choice for you.
also, go here http://www.tweak3d.net/tweak/geforce/print.shtml
and tweak it a bit and see if that helps
REMEMBER: to make a "clean" install of the driver. there are instructions on the page above.
Sunner
Oh six of you, such nice tidy uniforms, oh Im sooo scared!
What, you guys dont have sarcasm anymmore?
Oh, neverf mind me, im just a little drunk, is there anything betrter trhan good Swedish Vodka?
ABSOLUT VODKA RULES!!!
