Nvidia Driver Causing Kernel problem
desprado
1,645
What can i do to solve this crap problem which caused by nvidia driver.It only Freeze while playing games.I have tested my Gtx 780 sli and stress them by furmark of 30 mins no freeze there.I am using 326.41 driver
http://imageshack.us/a/img832/4325/207s.png
- System
- Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID 41
Version 3
Level 1
Task 63
Opcode 0
Keywords 0x8000000000000002
- TimeCreated
[ SystemTime] 2013-08-07T05:49:37.134734700Z
EventRecordID 6803
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer Ammar
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
SleepInProgress 0
PowerButtonTimestamp 0
BootAppStatus 0
stahlhart
Super Moderator Graphics Cards
Dec 21, 2010
4,273
77
Your build isn't stable, and that's a beta driver.
If anything, the fact that you're running FurMark for 30 minutes and not seeing the problem ought to be telling you something.
3DVagabond
11,951
204
Furmark is useless as the cards have software protection that kicks in as soon as it sees the executable and throttles the card's power.
What PSU are you using and what are your cards temps when playing games?
desprado
1,645
I am using xigmatek NRP-HC1001,normally card temps are 75C, and other one is one 74C and cpu temps are 65 to 67 not more.
desprado
1,645
^i have benchmark so many it never crash or froze it only does in gaming and while playing.Add one more thing while i was using furmark and i was also using prime96 with it and both where running no crash.
CPU 100% load
GPU 1 99% load
and GPU 2 98.9% load.
cmdrdredd
27,052
357
There is nothing to suggest that is an error caused by the Nvidia card or driver. I'd start with your memory, loop memtest for a while and see if you get memory errors, then run prime95 for 12 hours to verify CPU stability. Then you can rule out other factors. I've seen supposedly stable systems crash in a game because of a cpu error that only appeared when a specific game was running. Upping the voltage a bit cleared it right up. I could only verify it was the CPU by looping prime95 for a long time. It went 6 hours or so before it error'd out on one core.
Puffnstuff
16,256
4,930
Who the hell is that company? I think that I'd be putting a meter on the rails when you stress the system to see if the rails are sagging under load.
cmdrdredd
27,052
357
What are you talking about? DO you think Kernel Power is a PSU? It's an event error in windows error logging that basically means the computer shut down incorrectly.
cmdrdredd
27,052
357
xigmatek mr wizard.
Look up xigmatek. They aren't crap. In fact their PSUs are made by channelwell which is a big OEM that makes the thermaltake tough power line among others. They don't suck if that's what you are getting at.
