The 64 bit and x86 drivers with a ton of fixes and performance enhancements.
http://downloads.guru3d.com/Nvidia-GeForce-301.34-Beta-64-bit-download-2907.html
64 bit Nvidia GeForce 301.34 Beta 64-bit
x86 Nvidia GeForce 301.34 Beta 32-bit
Here is modded inf to work with all Geforce cards 8800 and above. Modded nv_disp.inf
www.hammiestudios.com/nv_disp.inf
- NVIDIA FXAA Technology – shader-based anti-aliasing technology available from the NVIDIA Control Panel that enables ultra-fast anti-aliasing in hundreds of PC games. FXAA delivers similar quality to 4x multi-sample antialiasing (MSAA) but is up to 60% faster, enabling substantially higher performance in games. FXAA is supported on all GeForce 8-series and later GPUs. Note: This feature is disabled for games that already have built-in support for FXAA.
- NVIDIA Adaptive Vertical Sync – dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience. Adaptive VSync is supported on all GeForce 8-series and later GPUs.
- NVIDIA Frame Rate Target – dynamically adjusts frame rate to a user specified target. Support for this feature is enabled via third party applications via NVAPI.
- NVIDIA Surround Technology – Adds the following new Surround capabilities. Visit GeForce.com to learn more.
- Add in a fourth accessory display to get access to your email, web, or other applications while you game.
- Maximize an application to a single physical display when in Surround mode (enabled by default).
- Confine the Windows Taskbar to the center display (enabled by default).
- Enable bezel peeking – a feature which enables users to temporarily peek behind the monitor bezels using a hotkey (Ctrl + Alt + B). This feature is designed to be used in conjunction with bezel corrected resolutions.
- Add or remove resolutions from the list of Surround resolutions (only those selected will be available to applications).
- Full center display acceleration for single wide display modes (center display must be connected to the master GPU).
- NVIDIA SLI Technology – Adds or updates the following SLI profiles:
- Alan Wake
- Call of Juarez: The Cartel
- Counter-Strike: Global Offensive
- Deus Ex: Human Revolution - The Missing Link
- Left 4 Dead
- Orcs Must Die!
- Portal 2
- Resident Evil: Operation Raccoon City
- Risen 2: Dark Waters
- The Darkness II
- Battlefield: Bad Company 2
- Crusader Kings II
- Max Payne 3
- Sniper Elite V2
- Street Fighter X Tekken
- NVIDIA 3D Vision – Adds or updates the following 3D Vision profiles:
- All Zombies Must Die! – rated Fair
- Ghosts 'n Goblins Online – rated Good
- Oil Rush – rated 3D Vision Ready
- Postal III – rated Good
- Rayman Origins – rated Good
- SevenCore – rated Fair
- Stacking – rated Good
- Unigine Heaven Benchmark v3.0 – rated 3D Vision Ready
- Wargame: European Escalation – rated Good
- Warp – rated Good
- Wings of Prey – rated Fair
- Krater – rated Poor
- Adam’s Venture Episode 1- rated Poor
- Blacklight: Retribution – rated Poor
- The Darkness II – updated in-game recommended settings
- Depth Hunter – updated profile
- Dirt: Showdown – rated Good
- Passion Leads Army Benchmark – rated 3D Vision Ready
- Resident Evil: Operating Raccoon City – Rated Fair
- rFactor 2 – changed rating to 3D Vision Ready
- Trackmania 2: Canyon – rated Fair
- Unigine 3.0 Heaven Benchmark – updated profile
- World of Tanks – changed rated to Excellent.
