NV4-disp.dll and BSOD on MSI K7T266pro-RU...help?
pvanosta
My system:
MSI K7T266 Pro2-RU, bios 3.3
Athlon MP 1900+
256 DDR PC2100 Samsung ECC
Geforce 2 TI 64 MB DDR, 23.11
SB Audigy latest XP Liveware drivers
Intel NIC S-Pro 10/100
Netgear FA311 NIC
CL DI-5633 modem/latest drivers
WinXP
Via 4-in-1 4.37
Problem: in OpenGL apps (Return to Castle Wolfenstein), I get bsod's referring to NV4_disp.dll being stuck in a loop.
All hardware has latest drivers/software as far as I know.
Anyone else have similar issues?
Thanks
It's a known issue with the 23.11 drivers. Go back and install the 21.83 drivers and you'll be happy.
Welcome to the club. It's an issue with Nvidia's drivers. Check out this site.
I run Win2k with a GeForce3 Ti200 and used to get hard locks all the time. I made my memory settings more conservative and reduced the PCI Texture Memory size. Problem solved. Good luck.
<< It's a known issue with the 23.11 drivers. Go back and install the 21.83 drivers and you'll be happy. >>
Whoops, I forgot that. Do that too, people have more success with those.
I had this problem too. I kept trying driver after driver and none worked but now my hercules drivers work. I don't know why but they do. I can only suggest keep trying drivers until you find one that works.
