Nuva Ring birth control
Jeter4MVP
Banned
hey. what if my girlfriend gets on this? what is it like? Also what if you dont fit through that ring? like its not the right size. Is it expandable? does it ever fall out?
thanks
With only four posts, there is NO way you have to worry about "fitting" through anything. You'll fit through everything, I promise.
thanks
It expancs aroudn the cervix, the hormones are the same, the risks are the same and the side effects are the same as a reular pill.
thanks
No it doesn't. You twist it, push it in, and the ring tries to expand. It is held in place by the vaginal walls. And the side effects are slightly less because the hormones aren't making a path through your digestive system, they are being directly absorbed by the vagina.
