- May 18, 2001
- 7,884
- 382
- 126
Project pics are here:
https://get.google.com/albumarchive...m/AF1QipOmkjeFDN8usy_fXsHxlraXhulcdKDn7-d_Ml0
Hi Everyone,
I'm in the process of building a climbing wall on my property. As I expected, there is a lot of engineering & problem solving involved, so I kind of think some of you might be interested. Please feel free to ask questions or leave comments/suggestions. I will try to remember to post all costs & lessons learned.
Here's the history of the project. I'm a climber, but the closest climbing gym is about an hour away. I started a couple of months ago thinking about building a small outdoor bouldering wall on my property. A bouldering wall is a low-to-the-ground horizontal wall vs. vertical walls that most people are familiar with; it's main purpose is for practicing technique. The original plan was to build it out of purchased lumber, but it soon became apparent that this would make my costs skyrocket.
Somewhere along the line it occurred to me that I could build the structure of the wall out of used utility poles. It turns out they can be relatively cheap if you find the right seller. As it turns out, I have about 3 friends who work for my local utility company... they are providing me with used poles for free. They are even delivering them for free. So I have requested 5 poles, 3 of which have been delivered already. 2 of the poles are about 25', the other is about 30' long. Since the poles are longer than I expected, I've scrapped the bouldering wall plan and I'm going to build more of a traditional climbing wall with about 24' vertical feet of climbing surface planned.
The plan is to place 3 of the poles in a tight triangular formation - approx. 4' apart (4' is the width of a sheet of plywood). I will put the poles 4' in the ground and tie the 3 poles together at regular intervals with treated lumber. 4' deep is normally a little shallow for a utility pole, but since the 3 will be braced on each other I'm pretty sure it will be rock-solid (this is basically the same design of a tower that real engineers built where I work). That will be my central tower against which I will tie poles 4 & 5 to create a total of four 4' wide climbing surfaces.
So the area where I want to put this thing is an extremely rocky section of the mountain where I live. The first problem I wanted to eliminate was whether or not I was going to actually be able to dig 4' deep... I got my post-hole diggers and went to work on a test hole. Luckily it was all packed clay, I didn't hit even a single piece of gravel.
The next problem is that the poles were dropped off at the lowest point of my property. They need to be moved 200-300 yards with an elevation gain of probably 50'-75'. Coincidentally a buddy of mine got a pole from the utility co. at about the same time; he said that he could deadlift the end of his and move it (with effort). So I tried to move one end of mine. It was way heavier than anything I've deadlifted at the gym, but I was able to move & lift it a few inches, and immediately tweaked my back. Lesson learned: absolute perfect form when lifting this crap. The injury took me out for a couple of weeks, but today I was able to carefully deadlift the pole with a lot of effort but no pain.
So the plan to move the logs was to use a tow chain to attach the pole to my truck hitch. While the wifey drives, I will feed roller logs under the pole to help it move along. With a lot of trial & error, what I finally figured out for attaching the poles was to nail a small piece of 2x4 near the end of the pole, then wrap the chain around the pole on the "long" part of the pole. The 2x4 piece keeps the chain from slipping off. This worked. The rest of the plan sort of worked but very poorly. The roller logs kept slipping out; the pole kept twisting; in the end, we moved one of the poles about a third of the way in an hour, and I was worn out from constantly putting the pole back on the roller logs.
We briefly tried to load the unattached end of the pole in a wheelbarrow, but it was very apparent that this wasn't going to work because the wheelbarrow couldn't handle the weight. It felt like an accident waiting to happen.
So that's where I am at the end of today. While in the shower I came up with a good plan... I have 2 wheelbarrows & a lot of scrap lumber. I am going to cannibalize the wheels from the wheelbarrows & build a sort of rolling attachment that I will put under the loose end of the poles. This is more or less how the utility co moves them and seems like a viable option. So far, the project has cost me $0.
Hi Everyone,
