Nuclear power plants
SarcasticDwarf
My understanding of modern nuclear reactions (the ones used for civilian power stations in the US) are designed such that the only way for a reaction to occur is if the plant is actively supplying a resource (meaning that if for whatever reason the plant was abandoned, attacked, had to be shut down), it is merely a matter of shutting down the flow. Do I understand this correctly?
you have to insert the control rods and then you still have to maintain cooling, by using the LPCI, HPCI, or RHR systems (or whatever the plant has)
Sounds like you have a fairly good understanding of modern nuclear reactors to me. But I of course know nothing at all about them.
Edit: For not Knowing about spelling either.
The fuel rods always remain stationary. The control rods are what control the reaction, and in modern nuclear plants they are designed to shut down the reaction just by way of gravity pulling them down into the core. So that even in the event of a complete system failure, the reaction will be stopped.
Ah, ok. Would that apply to both PWR and BWR reactors?
I believe so, but there are a lot of different reactor designs so it's kind of hard to make a broad statement. And I am by no means an expert on the subject.
Edit: After a bit of reading, it seems BWR reactors must have the control rods inserted from below, so the gravity fail-safe wouldn't work.
its called a SCRAM (shutdown control rod ax man)
the control rods are made of halfnium (neutron absorber) and raised up to start the reaction. if an emergency requires the reaction to be stopped, the rods are released (a loss of power also releases the rods) and are driven back down into the core to stop the reaction by both gravity and springs
this is called SCRAMing the reactor
civilian plants are a little different than naval reactors, but the basics of all PWR (pressurized water reactors) are the same
the real key to your question may be that a PWR core has a negative temperature coefficient
this means that as the temperature of the coolant rises, it introduces a negative reactivity, which tries to shutdown the reaction. this is temperature feedback, it enhances safety. the graphite reactor at chernobyl had a positive temperature coefficient, so as it got hotter/too hot, it causes the nuclear reaction to grow, which was bad
No, it wouldn't, PWR control rods are inserted from the top, and will fall in due to gravity, BWR control rods are inserted from the bottom since the steam equipment has to been on the top of the pressure vessel. However the BWR has some other failsafe mechanism so that the control rods will be inserted, but I don't remember what it is. Also, inserting the control rods only knocks down the power about 95%, there is still a substantial amount of power being generated by the spontaneous decay of short lived actinides produced by the reaction. So, you still have to maintain cooling or bad stuff can happen. So, its not a good thing if you just shutdown a reactor and then leave (it aint gonna blow up or anything though). The Gen 3+ reactors have additional passive safety measures in order to ensure cooling for ~3 days with not outside intervention.
EDIT: looked it up for BWRs, and they use a pressurized water system to insert the control rods on a loss of power.
The latter melted the pathway into which the control rods could drop, not allowing them to drop all the way, thus creating an even greater problem.
What were the Russkies thinking???
Originally posted by: eits
i'll ask my mom... she's a senior project manager for 3 nuclear power plants.
Heh. And my father has a Master's in Nuclear Engineering, specialising in reactor physics, from the University of London. 😀
Wikipedia has insanely long and detailed articles about this, and forty to sixty sources on each article; Wikipedia FTW!
Well MY dad has a masters in nuclear engineering from UVA and a MBA. Also my mom has a bachelors in nuclear engineering and an MBA as well 😛.
It does have articles, but the safety issue is largely ignored.
Haha, my daddy can kick your daddy's ass any day of the week!
Civilian power plants are different enough from navy power plants that I won't even pretend to be an expert on them, but a buddy of mine worked for a while at a civilian plant. The way he explained it to me, the control rods take you down below sustainable reactivity, but to completely shut down the reactor, you have to inject (if I remember right) boron into the coolant, which acts as a massive neutron "sponge", and pretty much kills the reaction.
Navy power plants, on the other hand, will pretty much kill all but background reactivity with the insertion of the control rods on a SCRAM action, and don't require the injection of boron into the coolant (which is a good thing, since I imagine flushing that crud back out is somewhat of a chore). Also, the production of fission daughters tends to act as neutron sponges after a reactor shutdown, making an immediate restart harder than the initial startup of the reactor (this effect is much more exagerrated toward the end of the reactor core life). Add to that the negative reactivity mentioned above, caused by the rise in coolant water temperature, and a scrammed navy reactor stays shutdown, unless a restart is initiated by the reactor operator.
Geez, I almost sound like I still know what I'm talking about, don't I?? The funny thing is, I can't hardly tell you what I had for dinner 2 nights ago, but I can still remember crap like this, that I learned over 25 years ago!!! :roll: :laugh:
Hopefully that answers your questions, SarcasticDwarf?? Oh yeah, here's something else I remember......navy nuclear power class number 8107. Dang, that was a loooooong time ago!! 🙂
i was 8602 , the second class at the new NPS Orlando
:Q
i had, something for dinner friday, i don't know
cool. my mom graduated from the university of michigan. she got her master's at johns hopkins.
