Nuclear Multi-Core CPU benchmark
VirtualLarry
56,548
10,171
What are people getting for an L1 cache speed? My friend's system is showing something along 150,000, which IMHO can't be right. WTF is up with this benchmark.
Edit: Maybe I'm wrong. I guess I get 160,000+ for an L1 score on my box.
Rubycon
Madame President
Aug 10, 2005
17,768
485
See the pic(s) above. Perhaps an extra zero was added? ;)
SRoode
243
AMD X2 4400+ @2200 (Stock), 2GB DDR400 (2-3-2-5)
ALU = 3497
FPU = 4123
MT = 7073
SCORE = 5876
Edit: I noticed that Kroffty (above) has his AMD single core CPU clocked 35% higher than mine, with only a 26% increase in score in ALU and FPU. Kroffty, what is your RAM speed/latency?
Kroffty
? I will check.
I May have set This one up while drinking.
Oh I have kinston hyperX 4000 ram
Kroffty
Thanks for the heads up.
everest ultamate
Field Value
Memory Speed PC3200 (200 MHz)
Field Value
@ 200 MHz 3.0-3-3-8 (CL-RCD-RP-RAS) / 11-14-2 (RC-RFC-RRD)
I Think I can do way better. I just never checked it sober.
:Q
Kroffty
OK I did a quick shot in the arm to the ram
CAS Latency (CL) 2.5T
RAS To CAS Delay (tRCD) 3T
RAS Precharge (tRP) 3T
RAS Active Time (tRAS) 6T
alu = 4743
fpu = 5559
mt = 5197
score 5109
SRoode
243
alu = 4743
fpu = 5559
mt = 5197
score 5109
That looks much better... 35% more clock speed than my CPU, 35% higher alu/fpu!
myocardia
9,291
30
alu = 4743
fpu = 5559
mt = 5197
score 5109
That's better, but you should score higher than that, I would think. Run your system at 12 (cpu multiplier) x 247 (HTT bus)= 2964 Mhz; your score will be higher, and so will your overall system performance. Oh, you'll need to set your RAM divider to 1:1 (200 Mhz, or 400 DDR, or whatever your motherboard calls it). Oh, and don't forget to change your HT or LDT multiplier to 4x, and put your RAM timings back to where they were before you changed them.
VirtualLarry
56,548
10,171
3701 Mark
Intel C2D Celeron 440, 2.0Ghz, 512KB L2, 1GB DDR400 3-3-3-8 DC
Originally posted by: Noema
3735 Total Mark on my Single Core A64 3200 2.2GHz (NewCastle core and 1GB of DDR PC3200 RAM).
So much for the superiority of the C2D over the A64. It seems that AMD's price/performance is very competitive at the low end. I paid $70 for the 2.0Ghz 440, you can get a 2.4Ghz 4000+ for less. C2D is only worth the money if you overclock. At stock speeds, AMD is the p/p winner.
Idontcare
21,110
59
Kinda extreme to state that based merely off of one little-known and somewhat dubious benchmark program you stumbled across on a forum thread...don't ya think?
Noema
2,974
5152 Score on a Core Duo "Yohah" @1.83GHz, 2MB L2 Cache (Dell Inspiron 6400 Lappy); 1GB of DDR2@557MHz.
Not bad for a mid-range lappy. Too bad the 4200RPM HDD really cripples it :(
VirtualLarry
56,548
10,171
I'm just saying that with a crippled L2 cache (only 512KB), C2D performance doesn't really scale like it should.
XBitLabs showed that an AMD X2 3600+ was comparable to an E2140 (or was it the E2160) in most things, and the AMD chip is cheaper.
Accord99
2,259
172
And the 3600+ has 19% more clockspeed and the E2140 still beat it most applications.
It's precisely the superiority of the C2D over the A64 that has forced AMD to price their products the way they are. When you don't have the outright performance lead, then you have no choice but to win price/performance. No different than when the situation was reversed and Intel had to price the P-D 820 and 805 at well below the cheapest AMD dual-cores.
Rhoxed
1,051
3800+ x2 Toledo @ 2.7ghz
Score: 7169
gonna try it at 2.8 and higher ;0
EDIT: got it to 2.8 stable only for the test couldnt get any higher :(
@ 2.8
Score: 7512
Mir96TA
1,950
37
P4 EE @ 3.4Gig
Score is 3295
My Core E440 2 Gig with DDR 400 on ASRock
is ALU 3660
FPU 5273
MT 7623
Total 6292
Core E440 with DDR II P35C-DS3R GigaByte
ALU 3689
FPU 4270
MT 7631
Totat 6302
myocardia
9,291
30
Well, I finally got around to running this on my Opteron. I guess 7,680 isn't too awfully bad for an A64.
