Nubee Question:Linksys Router Problems
420benz
I was under the impression that this was the best. Not True.I am constantly reseting it at least 3 times a week.I called CS and went through a lot of typing in Run but it did not help.
jamesmcuk
217
are you resetting because you lose internet or total connectivity as in you can't even log in to the router management?
420benz
I will open my laptop about 40ft from router and there will be no connection. If i go through [how to fix] i never get anywhere. I must reset the router.
jamesmcuk
217
its not sat on top of any other electrical equipment is it. Also maybe worth disconnecting the modem to see if your router still hangs when its not connected.
420benz
It's sitting on top of my PC tower.I will move it and see what happens.
