ntune hardlocks my system
cpush
235
Recently, and I have no idea why, nTune has decided to hardlock my system when I try opening it. It has worked fine for the last 2 months I've had my system. I started experimenting with memory timings and wasn't too successful. I noticed nTune would lock up my system, so I set everything back to my previous set up and it still crashes my system, I have re-installed the program and no luck. Any info would be appreciated. thanks
vnf4 ultra
venice 3200
1gb geil pc4000
ocz modstream 450
ghidu
331
I'm in the same situation. When I open it my computer locks itself after few seconds.
Bona Fide
Banned
Jun 21, 2005
1,901
Is nTune part of the BIOS? If so, you might have to reset the CMOS jumper on your motherboard. It'll wipe out all of your overclocking settings and what not, but I'm not sure what else to do. Then again, I'm not too familiar with nTune.
dwcal
765
nTune is a Windows utility. It's probably trying to OC your system too high when it launches. It might store it's settings in the registry which stays behind in a reinstall. I gave up on nTune myself and used ClockGen instead.
