- Feb 24, 2002
- 3,126
- 0
- 0
Okay here's the deal. I have two hard drives. one hard drive had 2 NTFS partitions on it, C and D. The other hard drive is drive F, which is what I use all the time and run Windows off of. I decided to partition my drive and merge C with D. I run partition magic and it ruins my working partition, F. Now I can't boot up into my Windows XP because it gives me the error message "NTLDR Missing Ctrl+Alt+Dlt to reboot." If I try to insert a Windows XP boot disk to fix it, it says to me that my hal.dll is missing. I presume that NTLDR is the Windows NT Loader, the black screen that pops up when I turn my system and select an operating system.
How would I go about fixing this? I really need to get to my F drive because it has all my files in it and I can't get them back because when I put the hard drive in another PC I am denied access. Does anybody have any ideas or has experienced this problem? Is this a hardware problem? Most likely not, because Partition Magic caused it, but whatever.
Thanks in advance.
Thanks in advance.
