I'm about to get a new PC with a 40GB drive and was thinking which OS to install and how to partition the drive. This isn't gonna be a gaming PC, more for heavy graphics (Photoshop 6, Flash, Freehand etc...) so I need an OS that's fast and stable. I'm not sure that Win2K will work with all my apps so I'd like to dual boot Win98Se and Win2K.
I thought I'd initially install Win98SE in a small partition (maybe 2GB) and then install Win2k on almost all of the remaining space. I really don't won't to overdo the amount of partitions as the person using the PC doesn't want to hassle with this.
My questions are:
1. Is it wise to have such a large second partition? Won't defragging take forever?
2. Is it ok to install Win2K to a FAT32 partition (for file sharing purposes with Win98) or will I not be taking full advantage of the speed of Win2K if I don't use NTFS?
3. If I dual boot win98 and win2k and later decide to remove win98, is this possible?
Thanks for any advice you may have.
My questions are:
