NTFS conflicts with a FAT32 partition PLEASE HELP
tytan0
23
About a month ago, I was using win98 SE and I decided to upgrade to winXP. After completing the installation, I tried to install Earthlink, and that didn't work. AOL Instant messenger didn't work either. So i formatted, and installed win98 SE again. Then last week, I got a friend's copy of winXP and installed it. Again, the same problems occured. And this time, windows media player didn't work along with the other programs.
Today, I formatted the drive, and installed win2000. I then installed winXP, and still, barely any programs work. This installation was different however, because the computer asked me to format my main partition as either NTFS or FAT32. I chose NTFS, and formatted and installed XP. I have another partition on that same drive (D:), and after XP was installed, i went to drive D, and the files that I have been desperately saving for the past years seem to be gone. Any suggestions on recovering them? PLEASE HELP. thanks.
Lord Evermore
9,558
Those products won't recover files that have actually been formatted over, they only work for "deleted" files.
Ontrack Easy Recovery has been the most helpful utility I found for recovering files on a formatted partition. Of course if you've overwritten the drive with any other files, it will make it harder to retrieve the files.
Check the properties of the D drive, see if it shows as having NTFS formatting. It would be odd for Setup to format anything besides the primary partition.
