You need to have 2 NICs installed, one on the public IP address, one on the internal address. Then you go into properties of TCP/IP I believe and under the Routing tab, just select the "enable IP forwarding" check box. You make your internal NIC have a default gateway with the IP address of your external NIC, and your external NIC has the DG of your ISP. That's all there is to it.
