NT/Mandrake dual boot problems with LILO
jleon
I just rebooted after installeding Mandrake7.2 and at the LILO, it only shows linux.
I'm not sure what I did wrong. I have 4 partions. Primary has NT, second is Mandrake, 3rd is empty and 4th is a small 50 meg linux SWAP. Any ideas?
thanx
eeek, won't even boot up to linux as it hangs on the "Bringing up interface eth0"
I do have a nic card in there. I guess it wasn't configured correctly 🙁
<< it only shows linux >>
typing dos at the prompt should bring up the ntldr (if you have it), otherwise boot into nt. hitting the <tab> key should show you a list of what you can type.
<< eeek, won't even boot up to linux as it hangs on the &quot;Bringing up interface eth0&quot; >>
if your nic isn't configured correctly, it takes a loooong time for this to timeout. go make lunch and come back, it should be done by then.
