Hello,
In Win10 Task manager, there is a process that takes about as much as any HDD activity as the other processes that are running. This process seems to mimic all software when it comes to HDD use. CPU use is up to 25%, generally stays between 7-15%.
The process is listed as System. Going to properties it tells me it's: nt kernel & system and ntoskrnl.exe.
Some of the software which it mimics the HDD use: Firefox (downloaded a large file), Explorer (if I copy something from disk to disk), HD Tune and other HDD benchmarking software
There are articles and posts about ntoskrnl.exe taking too much CPU and HDD.
Tried all the solutions listed here:
https://www.drivereasy.com/knowledge/system-ntoskrnl-exe-high-memory-or-cpu-usage-in-windows-10/
https://appuals.com/high-cpu-or-disk-usage-by-ntoskrnl-exe-on-windows-10/
Does not fix it.
When I copy something (from disk to disk), in Resource Monitor Explorer does the reading, and System the writing. Same with Firefox.
In Resource Monitor System (or the other names) does not show up at all (including in process activity). It's just the piece of software that is writing things.
In Process Hacker in the processes tab there is no System(or other names), disk activity is the software using the HDD. In the Disk menu however, System is doing all the writing, the software used is not listed as doing much with regards to HDD use.
Is this just how HDD use shows up in Win10 Task manager?
Thank you.
Does not fix it.
Thank you.
